LMS 2.6 Netconfig jobs failing with pre-device deploy error
LMS 2.6 Netconfig jobs failing with pre-device deploy error.
This error has been occurring at random for the past 5 days. I have included a job log for reference. Please assist in determining the cause of this error and possible solutions. Thank you in advance
[ Wed Jun 10 20:35:58 CDT 2009 ],FATAL,[Thread-5],com.cisco.nm.rmeng.util.DCRWrapperAPIs,Connect2RME,2693,SQLException occurredjava.sql.SQLException: JZ00L: Login failed. Examine the SQLWarnings chained to this exception for the reason(s).
[ Wed Jun 10 20:35:58 CDT 2009 ],ERROR,[Thread-5],com.cisco.nm.rmeng.config.ccjs.executor.downloader.ConfigDLThread,run,122,Exception in Download ERROR:RME_CDL1001:Pre-Device deploy operation failed
Server info:
Windows 2003 server r2 sp1
LMS 2.6
-CiscoWorks Common Services 3.0.6
-Resource manager Essentials 4.0.6
-Campus Manager 4.0.6
-CiscoView 6.1.5
-Device Fault Manager 2.0.7
-Internetwork Performance Monitor 2.6.0
-No ACS integration
1 REPLY
Re: LMS 2.6 Netconfig jobs failing with pre-device deploy error
There appears to be a problem with your RME database. Try running the following command:
NMSROOT/bin/perl NMSROOT/bin/dbpasswd.pl dsn=rmeng
Reset the RME database password to a known value, then see if the job can run.
190
