10-13-2009 02:39 PM
When I attempt to export the job results of a Netshow job via the export job button... the export job options window pops up but the window is blank. I have included a screen capture of the blank export pop up window. Can you please assist in the isolation/ correcting this issue. Thanks in advance.
Windows Server 2003 SP2
CiscoWorks Common Services 3.0.6
Campus Manager 4.0.6
CiscoView 6.1.5
Device Fault Manager 2.0.6
Resource Manager Essentials 4.0.6
10-13-2009 03:00 PM
I cannot reproduce. what version of IE are you using? does the same behavior happen with Mozilla?
10-13-2009 03:16 PM
I am running IE 6 SP2 and the same results are produced with FireFox 2.0.0.3
The export function works flawlessly within other sections of ciscoworks.. like in report archive.
It doesn't appear to be a browser based issue because I can attach to another ciscoworks server using the same browser and perform a NetShow job export with out incident.
10-13-2009 03:23 PM
Shutdown Daemon Manager, and delete all of the files and directories under NMSROOT/MDC/tomcat/work/Standalone/localhost. Then restart Daemon Manager, and see if you can do the export.
10-13-2009 03:45 PM
The same results were achieved after the deletion of all files and folders under NMSROOT/MDC/tomcat/work/Standalone/localhost
'cwcli netshow jobresults' is not available in the cwcli executable available in LMS 2.6... correct?
10-13-2009 04:42 PM
I am not too sure how; why or when but the NetShowExport.jsp file was missing. I have imported the file back in to the necessary directory and now all is well.
This was uncovered by running process monitor.
Date & Time: 10/13/2009 7:08:38 PM
Event Class: File System
Operation: CreateFile
Result: NAME NOT FOUND
Path: E:\CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\screens\Tools\netshow\NetShowExport.jsp
TID: 8948
Duration: 0.0000813
Desired Access: Read Attributes
Disposition: Open
Options: Open Reparse Point
Attributes: n/a
ShareMode: Read, Write, Delete
AllocationSize: n/a
