Community Member
LMS 2.6 Report question
How can i do a report that will show me all my routers that have a secondary ip address on them?
1 ACCEPTED SOLUTION
Re: LMS 2.6 Report question
You can use the baseline compliance feature of RME to do this. Go to RME > Config Mgmt > Archive Mgmt > Baseline Templates, and create a new advanced template for your Routers group (or any other groups you may want). The template will simply consist of prerequisite command set, and one simple check for a ubiquitous command (like hostname):
IsPrerq : TRUE
Submode : interface [#.*#]
Body:
+ ip address [ADDR] [MASK] secondary
IsPrereq : FALSE
Prereq : SecondaryCheck
Submode :
Body:
+ hostname [NAME]
Then run a compliance check against all relevant devices. The resulting compliant devices have a secondary IP, and those excluded do not.
Community Member
Reason for this is..
Seams that when I do a device descover and then a data collection in CM 4.0.12 we have some old routes still in our configs.. And somehow it is reporting that there is a router maybe due to a static route that isn't there anymore? I am at a loss on what is happening...
IsPrerq : TRUE
Body:
IsPrereq : FALSE
Submode :
Body:
+ hostname [NAME]
158
