LMS 2.6 return to default settings after restarting daemon
Hi Everyone,
To you know any existing bugs or resolution to this issue:
after restarting Daemon Manager the settings of LMS 2.6 example Syslog returned to default settings.
Thanks.
Everyone's tags (2)
Re: LMS 2.6 return to default settings after restarting daemon
Specifically which syslog settings are reverting to their defaults?  Exactly what version of RME do you have?  On what platform is LMS installed?
It is not happening only in RME but also in DFM. For example, there are selected event set under Notification Services, after restarting the daemon all the events are unchecked. Although it is not always happening, sometimes the restart doesn't have any effect but sometimes it does reset the settings to default.
Appreciate your idea
Post a screenshot of exactly what you're seeing under Notification Services.
266
