LMS 2.6 - RME Job forwarding
Hello
It's possible to forward the results of all RME jobs to an predefined email address? (different from the email address defined from the job owner)?
For example: the administrator like to known all the Jobs applied from differents networks engineers.
Best Regards
Andrea
Re: LMS 2.6 - RME Job forwarding
You can set an email address to always be used for config jobs under RME > Admin > Config Mgmt > Config Job Options. However, perhaps you'd be better off using the Approver feature in LMS that will require all jobs to be acknowledged by a person or group of people before they can run. See the RME online help for more details on the Approver feature.
Hello
thanks for the answer.
Very interessant ist the Approver feature.
For the moment I will use the Automated Actions.
Best Regards
Andrea
107
