Webcast-Catalyst9k
LMS 2.6/RME : package installation failed
Customer wants to install 2960 package. I give her this package with all depency and the order to how install:
- LibCommon.RME40.v1-3-5.zip
- LibInventory.RME40.v1-11-7.zip
- LibSwim.RME40.v1-8-7.zip
- SharedDcmaIOS.RME40.v1-6-4.zip
- SharedSwimIOS.RME40.v1-11-7.zip
- SharedInventoryCatIOS.RME40.v1-4-3.zip
- SharedSwim2900XL.RME40.v1-7-4.zip
- SharedSwimRtr800.RME40.v1-6.zip
- Cat2960.RME40.v3-3.zip
She has an error message when she try to install SharedInventoryCatIOS.RME40.v1-4-3.zip, see page 4 on file attached.
You can find psu.log
Thanks, Elisabeth
1 ACCEPTED SOLUTION
Re: LMS 2.6/RME : package installation failed
They require a newer version of LibInvReports.  The latest version is 1.3.1.  It could very well be that this server's package repository is bad, and you will need to contact TAC to an up-to-date RME 4.0.6 package set.  Using that, you can properly populate the repository, and regenerate the package maps.
Customer has installed LibInvReports, latest version 1.3.1. And now she has installed succesfully :
Many thanks, Elisabeth
233
