Community Member
LMS 2.6 upgrade to 3.2
We have a LMS 2.6, how due I upgrade to LMS 3.2?
I have tried to just install CS 3.0 and then tried to run update LMS 3.0 but it will not run unless I update CS to 3.1.
I have install CS 3.3 with the CSCtc38080-0.pl and it was a sucess but under Software upgrade it still says CS 3.0.5.
Is it possible to upgrade LMS to 3.2 or due we need a new license we have a license for 2.6.
can I download LMS 3.2 and then use the same lic file?
Thomas
1 REPLY
Re: LMS 2.6 upgrade to 3.2
For 3.X you require a different licence
This you will have to order from cisco.
You can already download and install 3.2 but you will be limited to 100 devices and a 90 trail
You can get it here http://www.cisco.com/go/nmsevals
I don't think it is worth upgrading the 2.6. Better do a clean install of 3.2 and import a devices list. (That you previously export from 2.6)
Cheers,
Michel
200
