LMS 2.6 with IPM 2.6 integration ACS 4.1, problem with IPM
Recently I integrated ACS 4.1 with LMS 2.6 follow this document:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html
The integration was a partial success, because after the integration I cannot run IPM client and Reports. Just I don't have the icon to run this features.
Some of you know why is happen, and if there is a solution?
In accord with the document above, I check the integration and was everything how this doc says. But IPM give me this problem.
Thank you really much.
Best Regards Antonello.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: LMS 2.6 with IPM 2.6 integration ACS 4.1, problem with IPM
Do you see options for IPM in ACS under Shared Profile Components?
Thank you a lot Joe.
I wrongly thought that System Administrator has totally access.
Thank you really much, I rate you post.
359
