Community Member
LMS 3.0.1 CM 5.0.4 Cisco 6509 Switch VSS
We are running VSS on two 6509, device is present in DCR but although it is also present in CM 5.0.4 still its not recognized, listed as "ciscoProducts.896" under device type.Also I am not able to see both chassis in ciscoview & there is ? mark on icon in topology services. How to fix it.
1 REPLY
Re: LMS 3.0.1 CM 5.0.4 Cisco 6509 Switch VSS
VSS support is not available until Campus Manager 5.1, so you will need to upgrade to LMS 3.1 to get support for this device in Campus. For CiscoView, make sure you have Cat6000IOS package version 30.1, and the switch will be supported.
You can update your CiscoView packages under Common Services > Software Center > Device Update.
143
