You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
LMS 3.0.1 Problem with CM Device Discovery Report
I'm using LMS 3.0.1 (Windows server 2003). When I want to look at the devices discovered by Campus Manager (Data collection) I get a window with this message "An error occured in generating Discovery Details Report. Unable to moad properties from server. Please try after sometime."
What is the problem?
  • Network Management
1 REPLY
Re: LMS 3.0.1 Problem with CM Device Discovery Report
This could be CSCsl71054:
Symptom:
Trying to launch the Data Collection metrics report for the most recent Data Collection from the Campus Manager homepage generates the following error dialog:
Error
An error occurred in generating Discovery Details report. Unable to load properties from server. Please try after sometime.
Report could not be found.
Conditions:
This can occur if a Data Collection has not run fully, or if the date information is otherwise not available in the Campus Manager database.
Workaround:
Restart ANIServer, and run a new Data Collection.
A patch for this bug is also available by calling the TAC.
151
