LMS 3.0.1/ Switches 6509 SUP 710 /12.2 (33) SXI
Hello ,Dears all
I have met a problem with this kind of IOS.The CDP neighbors has been not notified under the Device Center Module.
and sometimes the same kind of switches can report the information.
Any Idea that can prove that is just an LMS configuration parameter missed ?
Does there is a bug existing on it ?
1 REPLY
Re: LMS 3.0.1/ Switches 6509 SUP 710 /12.2 (33) SXI
Can you make sure all credentials are correct for these devices?
Also, does an snmpwalk of the following return expected info:
.1.3.6.1.4.1.9.9.23
129
