Community Member
LMS 3.0.1 upgrade to LMS 3.2
Hi Pros,
Can anyone help me to know the step by step procedures for upgrading LMS to 3.2 from 3.0.1.
swami
1 REPLY
Bronze
Re: LMS 3.0.1 upgrade to LMS 3.2
There is no special procedurefor the upgrade.
All informations you will find in that documentation:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/overview.html#wp1086033
The only difficult point could be the ACS integration if you use that. It is possible to do the integration once again because of new features.
Sven
208
