LMS 3.0 an d eDirectory authentication
We have a eDirectory that we want to do the authentication.
I guessed that it is possible to select the Netscape choice and just do authentication using ldap/ldaps.
Is there anyone that has done this, or have any idea why it should/should not work.
/Per
Re: LMS 3.0 an d eDirectory authentication
Just if anyone else wants to know!
It works fantastic !!
1 minute to setup, and it worked.
Hi Per,
I am doing exactly the same but it is not working for me unfortunately.
Would you mind posting screen shot of setup?
Cheers
I assume that there are users in ldap which should not use LMS.
Have you tested if they can login to LMS? If this is the fact you should be aware of that and know that they have helpdesk permission.
118
