04-15-2008 07:24 AM
hi all
i have just installed LMS 3.0.1 (windows version) and updated with December 2007 patch. I'm trying to integrate it with my existing ACS infrastructure in two ways:
devices bulk import
aaa mode
(i made all conifugrations following the documentation)
i got several problems:
trying the bulk import from ACS, the system returns to me this error:
Import from ACS failed: For input string: ""
trying the AAA integration, the system returns to me that the AAA Client is not configured (even if it is)
any ideas?
thanks
Marco
Solved! Go to Solution.
04-15-2008 08:49 AM
Both problems might be related. Check the ACS configuration, and make sure you have all the TCP ports open for admin sessions. Additionally, if this is an ACS appliance, make sure you are NOT using the appliance administrator username as the ACS admin username in LMS. Create a new ACS administrator user with all ACS access permissions.
04-15-2008 08:49 AM
04-17-2008 02:49 AM
thank you very much!
