06-02-2009 08:48 PM
Dear
I am using LMS3.0, in CM topology view when I want to see Bandwidth utilization and select one of the option(low, high, medium). It shows no color indication for specific utilization level. how can I fix it. I am not using HUM. Is this the function of HUM?
06-02-2009 08:52 PM
HUM is not required. Campus uses RMON to determine link utilization. Make sure you have configured RMON on your links under Campus Manager > Visualization > RMON Configuration.
06-03-2009 03:12 AM
Thanks, my problem resolved.
