Community Member
LMS 3.0 DCRServer down
Whenever I try to edit Device credentials, I get an Error message that DCR server may be down, please restart.
I checked the processes in the control panel, all were up, but I found that the IPM NG process is manual, not automatic, and according to an old post in this forum it should be auto, but that was lms 2.5.1. I havent restarted the service yet.
I checked pdshow, everything seems fine, below is pdshow DCRServer
Process = DCRServer
State = Running normally
Pid = 9000
RC = 0
Signo = 0
Start = 5/5/2008 8:34:17 AM
Stop = Not applicable
Core = Not Applicable
Info = DCRServer is up and running
I have one more question, if we have only the SNMP RO string for the seed device, no other credentials, will this be a reason for not seeing host IPs in other vlans.
All help is appreciated
1 ACCEPTED SOLUTION
Re: LMS 3.0 DCRServer down
First, make sure that you disable all anti-virus scanning of NMSROOT as this has been known to trigger the problem you're seeing. If AV scanning is occurring in NMSROOT, disable it, then restart dmgtd. If the problem persists, post the dcrclient.log.
Discovery only uses SNMP RO, so this would not explain what you're seeing. I recommend you start a new thread to troubleshoot your discovery issue. Include the exact version of Common Services and Campus Manager, as well as how you have defined your Discovery settings.
Community Member
Thanks, DCRServer is up now
201
