LMS 3.0 December upgrade - portal issue
Yesterday I deployed the December upgrade for LMS 3.0 (along with HUM) and the portal is no longer showing the RME portlet in the Functional section (this section cannot be customized). Anyone else had similar issue?
Re: LMS 3.0 December upgrade - portal issue
Try re-registering RME under Common Services > Server > Homepage Admin > Application Registration.
Thanks, it did the trick. If you do not mind, here is another question about another (known bug) issue with the Dec update: the snmpwalk no longer works (in Device Centre Tools section). I'm able to do it from the OS itself to any devices managed by CW.
I did install NetSNMP, GCC346, openssl 0.9.8 from SunFreeware for Sol 10 (/usr/local). The lib file was modified:
Configuration file [version 4]: /var/ld/ld.config
Default Library Path (ELF): /lib:/usr/lib (system default)
Trusted Directories (ELF): /lib/secure:/usr/lib/secure:/usr/local/lib:/usr/local/ssl/lib
However I was not sure if CW uses ld.config
Also, does it (CW) need to have access to the /usr/local/bin for snmpwalk binary
Please start a new thread for this issue.
116
