12-20-2007 12:19 PM
Greetings. I'm trying to set up archive managment in LMS3.0, specifically RME 4.1.0, and I would like to schedule several different backup routines.
- Every 6 hours for core and distribution
- Every 24 hours for edge gear
I see the ability to set up an archive for specific subsets of machines under Resource Manager Essentials -> Config Mgmt -> Archive Mgmt -> Sync Archive, but that looks like it will only run for a single day, whereas I'm looking for something permanent.
I also see the ability to schedule permanent, recurring jobs under RME -> Admin -> Config Mgmt -> Archive Mgmt -> Collection Settings, but that applies to every machine.
Is there something I'm missing?
Solved! Go to Solution.
12-20-2007 12:38 PM
Unless LMS 3.0 differs from LMS 2.6, you should be able to do what you're looking for by scheduling Sync Archive jobs "6 - hourly" or "Daily" using the Run Type pulldown menu. I don't think the different Sync Archive jobs would overwrite each other.
12-20-2007 12:38 PM
12-20-2007 01:07 PM
Yeah it looks like the wording just tripped me up. Once the first job ran it scheduled the next one autmatically. Thanks for the quick input!
1. 1093.2 Sync Archive Scheduled Co
nfig Backup admin Dec 20 2007 19:00:00 - 6 - hourly
2. 1093.1 Sync Archive Successful Co
nfig Backup admin Dec 20 2007 13:00:00 Dec 20 2007 13:00:50 6 - hourly
