LMS 3.0 Discovery problem
Dear All,
I am using LMS 3.0, my problem is when scheduled discovery started, it does not finish and continuously running when I click device discovery page to see the status I got this error(snap shot attached). first time I resolve this issue by restarting Daemon manager, but now it becomes a daily issue. Is there any patch available to resolve this issue permanently.
Re: LMS 3.0 Discovery problem
Please post the output of the pdshow command.
Output of the command "pdshow" is attached.
It looks like Discovery has crashed. Do this. Run the following command on the server:
pdterm CSDiscovery
Then, delete the NMSROOT/conf/csdiscovery/DiscoveryStatusObj. then try re-running Discovery, and see if it completes.
It seems that there is no such file.
# pwd
/opt/CSCOpx/conf/csdiscovery
# ls -l
total 590
-rw-r----- 1 casuser casusers 13136 May 27 13:46 CSDiscovery-config.xml
-rw-r----- 1 casuser casusers 773 Aug 24 2007 CSDiscovery.mf
-rw-r----- 1 casuser casusers 30 May 28 07:04 SNMPv3CacheParam.properties
-rwxr-x--- 1 casuser casusers 21760 Nov 1 2007 SharedDiscoveryAUS.zip
-rwxr-x--- 1 casuser casusers 20377 Nov 1 2007 SharedDiscoveryCluster.zip
-rwxr-x--- 1 casuser casusers 129069 Nov 1 2007 SharedDiscoveryGeneral.zip
-rwxr-x--- 1 casuser casusers 85345 Nov 1 2007 SharedDiscoveryIGX.zip
-rw-r----- 1 casuser casusers 1178 Oct 29 2007 csdiscovery-ctm-log4j.properties
-rw-r----- 1 casuser casusers 1625 Oct 24 2007 ngd-log4j.properties
-rwxr-x--- 1 casuser casusers 2675 Sep 19 2007 removeCSDiscovery.pl
-rw-r----- 1 casuser casusers 10472 May 27 13:46 system-config.xml
# ls
CSDiscovery-config.xml SharedDiscoveryCluster.zip ngd-log4j.properties
CSDiscovery.mf SharedDiscoveryGeneral.zip removeCSDiscovery.pl
SNMPv3CacheParam.properties SharedDiscoveryIGX.zip
system-config.xml
SharedDiscoveryAUS.zip csdiscovery-ctm-log4j.properties
Okay, then just stop the CSDiscovery process.
141
