10-18-2007 07:29 AM
hi,
installing on a Solaris 9, after checking all the packages i need to install, I receive this fault:
INFO: Checking dependencies
/cwtemp/setup/dp.sh: -classpath: not found
ERROR: no ordered.list file
Finished: Thu Oct 18 16:06:41 MEST 2007
===============- Software Installation Tool Completed -==============
===================- Possible Warnings/Errors Encountered -===================
WARNING: Ensure that you have installed the recommended Solaris 9 cluster patche
s released
WARNING: on Dec/11/06, in this server.
WARNING: If these cluster patches are not installed, please download and install
them
WARNING: from http://www.sun.com/.
WARNING: Otherwise, some features of the CiscoWorks applications will not functi
on properly.
10-18-2007 07:50 AM
In the dp.sh script I've put these lines:
echo "JRE_CLASSPATH: "$JRE_CLASSPATH
echo "JRE_EXE: "$JRE_EXE
And re-running the installation this is what I can see:
JRE_CLASSPATH:
JRE_EXE:
So it seems no variable has been set
10-18-2007 08:01 AM
Hi.
First, I would encourage you to install directly from the CD, but if that's not possible, you must follow the instructions as laid-out in the install guide for copying the contents of the cd to the local disk:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/lms/lms30/igsg/prep.htm
â¢We recommend that you run the installation from a local CD or a local hard drive to avoid errors that may result from the network being slow or busy.
If you want to install from a local hard drive, you must copy the contents in a CD to a local hard drive. Ensure that you copy the entire contents from the CD to the hard drive.
If you are installing on a Solaris 9 system, you must preserve the timestamp when you copy the contents from the CD to the hard drive.
To preserve all the attributes including timestamp:
a. Change the present working directory to the directory to which the CD is mounted using the command:
cd /cdrom/cdrom0
where cdrom/cdrom0 is the directory to which the CD is mounted.
b. Create a directory where you want to copy the contents of the disk by entering:
mkdir /opt/copydisk
Make sure that this directory has enough space to hold the entire contents of the disk.
c. Enter:
tar cpf - . | (cd /opt/copydisk && tar -xpf -)
This command preserves all attributes including the timestamp.
If these procedures are followed, you should have no problems.
HTH,
-J
10-18-2007 08:57 AM
Thanks.
But ...I think there's another kind of problem. I've no problem with the file properties. And the installation location is a path on the system (as you can see /cwtemp/setup/). The problem is to have no result printing the environments.
The error "/cwtemp/setup/dp.sh: -classpath: not found" is because of the env problem. The line in the script was:
$JRE_EXE -classpath .:$JRE_CLASSPATH/rt.jar:DH.jar DependencyHandler /tmp/cscotm
p/setup "$src_depends" /tmp/cscotmp/all
But JRE_EXE and JRE_CLASSPATH are null.
So you have a command line like this:
-classpath .:/rt.jar:DH.jar DependencyHandler /tmp/cscotm
and so the error message.
06-23-2008 09:53 PM
have you solved the problem in the meantime?
And if, what was the solution?
