03-20-2009 05:16 AM
After installing LMS3.0, I have a full of event in the event log
Source : InCharge
Description : CI-E-EWHILE-While executing function "read"
CI-EFLOWID-For flow CI_FlowTCP_U [] IN_FLOW|PHYSICAL
. *:9002 KS 18-mars-2009 11:18:12, KR 18-mars-2009 11:18:12
. Open fd=3416, 0.0.0.0:9002 -> 127.0.0.1:47841, tmo 0 00:01:00 N/S 1/0
<SYS>-zWSAECONNRESET-Connection reset by peer; in file
"S:/DFM-3.0/12/smarts/clsapi/ci_flow.c" at line 1793
Is anyone has encounter this issue?
My server runs under 2K3 R2
Solved! Go to Solution.
03-20-2009 12:22 PM
This may be related to CSCsm04957. The fix is to upgrade to LMS 3.0.1 then DFM 3.0.4. LMS 3.0.1 can be downloaded from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 , and then DFM 3.0.4 can be obtained from Common Services > Software Center > Software Update.
03-20-2009 12:22 PM
03-24-2009 01:00 AM
Thanks for your answer. I have installed yesterday the updates and since there no more errors in event log. Great!
Regards, Cyril
