LMS 3.0 - TCP and UDP ports
Does anyone know the TCP or UDP ports to connect to the ANI (Campus Mgr) and rmeng (RME) databases?. I am trying to connect (retreive) info from the databases .. but I cannot find the TCP ports.
P.S. Yes I know Cisco does not like it when any external connection is made:-)) and I know abt the dbreader
1 ACCEPTED SOLUTION
Re: LMS 3.0 - TCP and UDP ports
All the ports used by LMS can be found at http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_quick_start09186a008073eddf.html#wp1027676 . The database ports are listed there.
Sorry I posted the same msg. in the Security forum... dont know how to move it from there so I posted again.
Thks jclarke. I knew i had seen that url but could not find it. saved it now.
121
