03-25-2009 03:58 AM
I tried to update an LMS 3.0 to view the
VSS devices .
When we tried to update software from Common Services , CISCO.Com send us back
a message saying that there is no update available, that's conform with the functionning of the software.
So, i have decided to update devices packages to see if there some availables from web.What i have remarked it's that
there is a module called "Integration Uility in LMS 3.0.1 not installed in LMS 3.0.
So , what the exact function of this module, does he take into account specific devices ?
Nota, The Device Updates give us just the opportunity to install the 2918 ones.
Solved! Go to Solution.
03-25-2009 10:21 AM
LMS 3.0.1 cannot be downloaded from Software Center in LMS. You need to download the mega-patch from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 . However, if you want VSS support for Campus Manager, you need to upgrade to LMS 3.1.
If your customer has a SAS contract covering LMS 3.0, then they can go to http://www.cisco.com/upgrade/ and request an upgrade DVD.
03-25-2009 04:00 AM
In fact , the customer would like to integrate theirs pix and 3560 devices.
03-25-2009 10:21 AM
04-20-2009 01:11 AM
Thank
I had a SAS contract covering LMS 3.0
so, i have received the LMS 3.1 dvd.
Thanks very much
