03-25-2008 09:01 PM
How to add devices in LMS 3.0 ? My setup is
switches---(dmz)firewall(inside)---LMS 3.0
What are all the ports i have to open in the firewall if i want to add DMZ switches in LMS 3.0 ?
Could you help me the step by step solution for this ?
Your reply will highly appreciated.
Thanks.
Solved! Go to Solution.
03-25-2008 09:20 PM
The required ports can be found at http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0/install/guide/prereq.html#wp1075786 . You need to open all the ports labeled Server to Device and Device to Server to get full manageability.
03-25-2008 09:20 PM
03-26-2008 11:52 PM
Thanks.. It is really useful.
