LMS 3.1: Backup done, but process still running
I started a manual backup yesterday afternoon, planning to upgrade the CM and DFM modules. Today, I saw that the backup had been created but nothing in the dbbackup.log file (0 byte in size). I tried to run backup again and got an error message. I checked the dbbackup.log again -- this time the file is 2527057 bytes long and at the end of it I see this:
[Tue Aug 25 19:49:46 2009] Backing up database dfmInvDb:SQL Anywhere Command File Hiding Utility Version 10.0.1.3694
SQL Anywhere Backup Utility Version 10.0.1.3694
(1073 of 1070 pages, 100% complete)
Database backup completed
[Wed Aug 26 14:51:54 2009] ERROR(247): F:/CW-Backup/backup.LOCK file exists
Most probably another backup process is running
[Wed Aug 26 14:51:54 2009] Backup failed: 2009/08/26 14:51:54
email=weiwang@med.umich.edu
host=UMMCCISCOWORKS
So it seems to me that the database backup has been completed yesterday but the processes are still running -- I checked and found these:
$ ps xa -W | grep db
23572 0 0 23572 ? 0 19:49:47 E:\PROGRA~1\CSCOpx\objects\db\win32\dbvalid.exe
17604 0 0 17604 ? 0 19:49:47 E:\PROGRA~1\CSCOpx\objects\db\win32\dbeng10.exe
5280 0 0 5280 ? 0 19:49:48 E:\PROGRA~1\CSCOpx\objects\db\win32\dbsupport.exe
Any idea why? How do I remedy this? Can I just kill those processes?
Thanks in advance for helping.
1 REPLY
Re: LMS 3.1: Backup done, but process still running
This is something we're seeing a lot of lately. Basically, the DFM INV database gets corrupt periodically. This is due to a bug in Sybase, and is fixed with the version of Adaptive Server Anywhere shipping in LMS 3.2.
To temporarily solve this, you need to either restore LMS from a known good backup, or reinitialize the dfmInv database:
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
To recover from the hung backup, shutdown Daemon Manager, then kill off the remaining database processes. At that point, you can either run the restore, or reinitialize the INV database.
311
