puk
Community Member
LMS 3.1 CM Discrepancies
Hi, is there any possibility how to purge all discrepancies which are already fixed? I know there is an Acknowledge option but would like to have an actual status without checking all the retired discrepancies.
Thanks for your ideas.
1 ACCEPTED SOLUTION
Re: LMS 3.1 CM Discrepancies
Data Collection must not be picking up the correct VLAN information. It would probably be best to open a TAC service request so Data Collection debugging can be enabled. Alternatively, if there is stale data in the ANI database, reinitializing it, then running a new Data Collection could resolve this. To reinitialize the ANI database, run the command:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI
Discrepancies which are fixed will automatically clear on the next Campus Data Collection. You can also restart Daemon Manager, then run a new Data Collection which will cause Campus to rediscover all active discrepancies.
puk
Community Member
Thanks for your info. It looks logically but in our case it does not work. The discrepancies were fixed long long time ago and also after a lot of Campus Data Collections it is still there. What do you recommend? Open a TAC?
What is one of the discrepancies which are still active (include all details)?
puk
Community Member
Type Trunk VLANs Mismatch
Severity Medium
First Found 30 Sep 2008, 12:18:44 CEST
Description [aaa,GigabitEthernet0/1], [bbb,GigabitEthernet8/5]
Detail This Trunk Link has ports with mismatching active VLAN sets.
Port GigabitEthernet0/1 on device aaa trunks following VLANs:
Device type and OS version of aaa:
Cisco IOS Software, C3550 Software (C3550-IPBASEK9-M), Version 12.2(40)SE, RELEASE SOFTWARE (fc3)
Port GigabitEthernet0/1 on device aaa does not trunk the following VLAN indices:
Index:9
Index:30
Index:15
Index:34
Port GigabitEthernet8/5 on device bbb trunks following VLANs:
Device type and OS version of bbb:
IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF15a, RELEASE SOFTWARE (fc1)
SERVER1 present in VTP domain GEBC_3.193.44.7(T) and having index 15
PHONES3 present in VTP domain GEBC_3.193.44.7(T) and having index 9
SERVICE present in VTP domain GEBC_3.193.44.7(T) and having index 30
MGMT_SRV present in VTP domain GEBC_3.193.44.7(T) and having index 34
Note: This discrepancy does not hold good if devices on either end of the trunk support different number of vlans.
aaa#sh run int gi0/1
Building configuration...
Current configuration : 174 bytes
interface GigabitEthernet0/1
switchport trunk allowed vlan 9,15,30,34
switchport mode trunk
end
bbb#sh run int gi8/5
Current configuration : 262 bytes
interface GigabitEthernet8/5
switchport
switchport nonegotiate
no ip address
udld port
spanning-tree guard root
end
174
