LMS 3.1 Error
We use LMS 3.1 with the available patches installed.
I wanted to configure some device credentials and identities.
After clicking "Apply" the following error was displayed:
"Internal error in communication channel.
Already installed patch for bug CSCsu84143.
Any ideas? Advice? TIA
Re: LMS 3.1 Error
What is the byte size of NMSROOT/lib/classpath/com/cisco/nm/dcr/InternalDCR.class?
Re: LMS 3.1 Error
Right now it is 8KB in size.
Re: LMS 3.1 Error
What is the BYTE size?
Re: LMS 3.1 Error
What are you asking for?
Re: LMS 3.1 Error
The size in bytes of the file. The kilobyte size is not accurate enough. You can get the byte size from DOS or from the Properties on the file.
Re: LMS 3.1 Error
7,592 bytes.
Re: LMS 3.1 Error
Okay. Enable Device and Credentials Repository debugging under Common Services > Server > Admin > CS Log Configurations, reproduce the problem, then post the dcr.log and the output of the pdshow command.
Re: LMS 3.1 Error
I'm having the same issue. Should I open a TAC case?
Re: LMS 3.1 Error
You'll either need to start a new thread, or contact TAC.
167
