ā01-13-2010 07:34 AM
Running LMS 3.1 RME 4.2.0 when trying to do a software update or upgrade analysis under RME Software management I am not able to select any device in the Device selection window. I can put a tick in All devices checkbox but it doesn't actually select any devices. I can drill down to an individual device but cannot select it. no tick appears in the checkbox. Please assist
Solved! Go to Solution.
ā03-26-2014 11:45 PM
I am having the same issue , rebooting doesnt help
Any other solutiuon to this ?
ā01-13-2010 10:24 AM
This sounds like an RME package problem. Post the swim_debug.log in addition to the NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log.
ā01-14-2010 05:54 AM
ā01-15-2010 02:10 PM
I'm not seeing any relevant errors to what I think you are describing. Post a screenshot illustrating the problem.
ā01-18-2010 03:14 AM
ā01-18-2010 11:49 AM
This is config archive, not SWIM. Post the dcmaservice.log and dcmaclient.log.
ā01-19-2010 12:56 AM
ā01-19-2010 12:36 PM
Post the list of contents under NMSROOT/MDC/tomcat/webapps/rme/lib/pkgs.
ā01-20-2010 12:18 AM
ā01-23-2010 09:35 AM
I was hoping for the output of DIR for this directory from a DOS prompt. I would also like to see a DCR export for one of the devices which is not selectable.
ā01-27-2010 12:18 AM
Since we have reboot the server this We we can now select device in RME .
Many thanks for your help.
Yannick
ā03-27-2014 04:21 AM
Rahul,
I think you have issues with your LMS 3.1 server which has been advsied in some other threads to upgrade to atleast LMS 3.2.1 which is free upgrade for you.
Using a End of support product will have consequenses of lack of support mostly. Let us know the challenges you have in upgrade.
People here in CSC can help and suggest solutions.
-Thanks
Vinod
ā03-27-2014 01:43 AM
Hello aryara
Our LMS 3.1 is unplugged now ! Have you try to update RME 4.2 to the last release available ?
Yannick
