Community Member
LMS 3.1 integrating to ACS
Hi, I have trouble to connect LMS to ACS. There are version of ACS 4.1 and LMS 3.1
When I start registration of applications to the ACS, I have trouble in the second step HTTP/HTTPS Connectivity, there are message: Mismatch protocol
But the connectivity to ACS from the server is OK. When I try: telnet acsserver 2002, that is correct response.
I can start web interface of acs from this server, web interface is available properly. There is no problem.
I don't understand, why LMS has this strange behavior. If anybody know what could be a problem, please note.
Thank you very much
Sarka Tesarova
1 REPLY
Community Member
Re: LMS 3.1 integrating to ACS
did you try http and https?
try to integrate LMS server with ACS server in HTTP mode.
Try to no register application first.
109
