LMS 3.1 integration with ACS 5.0
Can i integrate LMS 3.1 with ACS 5.0??
While integrating, i found the below error message. ACS & LMS open via "HTTPS".
In ACS, LMS is added as AAA Client.
My LMS username is: admin
I am using the same username in "ACS Admin Name" while integrating.
Kindly suggest.
1 REPLY
Blue
Re: LMS 3.1 integration with ACS 5.0
LMS 3.1 (CS 3.2) supports integration with ACS up to v4.2:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.1/install/guide/getstart.html
You'll need to upgrade to LMS 3.2 (CS 3.3) to gain ACS 5.0 support, with a caveat it's "(only for authentication services)".
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.3/user/guide/admin.html
"This allows to you the authentication services. However, the authorization services should be used from the local CiscoWorks Server."
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.3/release/notes/cs33rel.html#wp79193
288
