LMS 3.1 - IPM and threshold, CM
1. I want to configure thresholds for sources in IPM and it should generate traps if those are violated. how to go about it?
2. Is there any way that the IPM traps generated, be processed by the same CW.
3. How to get UT-Lite for windows.
Joe Clarke
1. This is done when you configure the operation in IPM. You'll note that there is a panel for reaction configuration. That is where you configure the desired reaction type, and parameters.
2. LMS 3.2 offers the ability to configure IP SLA syslog messages on devices which RME can then process. This is not available in LMS 3.1.
3. UTLite can be found in NMSROOT/campus/bin on a Campus Manager server. You want to get the UTLite33.exe and the appropriate UTLite*.bat script for your network.
so what i understood is that i will get the UtLite executable and the appropriate Utlite batch file for my network under NMSRoot\campus\bin folder. is that right?
