LMS 3.1 - IPM DefaultICMPJitter
For some reason when I set the DefaultICMPJitter collector I receieve an error "config failed" The other collectors configure fine. Any help is appreciated.
  • Network Management
Re: LMS 3.1 - IPM DefaultICMPJitter
ICMP Jitter requires a source device running 12.4(6)T or higher. Is this the case? Do you have your SNMP read-write credentials properly configured on the device and in DCR?
I am running 12.4(13r)T. Yes, SNMP RW has been implemented. DCR has been verified with correct credentials.
This doesn't sound like a correct version. Please post the show ver from this device.
I check the core switch and the version is: Version 12.2(18)SXE1
Look like you answered my question.
Thank you.
194
