Webcast-Catalyst9k
LMS 3.1 patches
I can't find all the Common Services 3.2 patches after upgrade of the Cisco.com download area.
Only the 2 latest patches "cwcs32-win-CSCtb70407-K9.zip" and "cwcs32-win-CSCtc38080.zip" and none of them are cumulative.
Before the upgrade of the download area there was a lot more Common services 3.2 patches available for download.
where can I find all the other patches?
1 ACCEPTED SOLUTION
Blue
Re: LMS 3.1 patches
A few more are available at http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-cd-one (look for "common services 3.2").
Many more probably need to be obtained from TAC.
Blue
Re: LMS 3.1 patches
Re: LMS 3.1 patches
Thank you, that was the page I was looking for
Blue
Re: LMS 3.1 patches
Could you share where you found the "cwcs32-win-CSCtb70407-K9.zip" and "cwcs32-win-CSCtc38080.zip" downloads? I've never seen them before. I'm planning to upgrade to LMS 3.2, so I'd like to find out if I need these for Solaris.
Re: LMS 3.1 patches
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=268439477
Routing and Switch Management ->CiscoWorks LAN Management Solution Bundle ->
CiscoWorks Common Services Software
320
