05-11-2009 09:38 AM
Hello Is there any way to backup the licenses files to completely reinstall OS and LMS?
I'm having a lot of error since I upgraded to LMS 3.1 for Windows (for example: JRM server is down or inaccessible for this user). As I was using an Spanish Windows 2003 Server, I'm thinking about reinstallin an Englis Windows 2003 Server.
Solved! Go to Solution.
05-12-2009 09:31 AM
It's time to reinstall LMS from scratch.
05-11-2009 09:44 AM
Yes, installing on a non-US version of Windows will definitely cause problems.
If all you want to do is retain your licenses, then just backup the *.lic files under NMSROOT\etc\licenses. When you reinstall LMS, make sure Daemon Manager is down, then copy the backed up .lic files to NMSROOT\etc\licenses.
However, if you do a full LMS backup, the licenses will be backed up as well. You can then restore that backup, and your licenses will be restored.
05-11-2009 10:43 AM
Thank you.
I've tried the full backup, but I get this error:
[Mon May 11 20:27:02 2009] ERROR(969): Fatal error: Database engine 'cmfEng' co
uld not be started on database 'cmfDb' in Bulk mode..
[Mon May 11 20:27:02 2009] Backup failed: 2009/05/11 20:27:02
05-11-2009 10:49 AM
This problem points to either a corrupt database, or a corrupt database transaction log. However, if you really didn't do much with LMS since you installed on an unsupported OS, a full backup might be pointless. If you want to try the full backup, I can provide the steps to try transaction log recovery.
05-11-2009 10:51 AM
Sure, I would like to try to recover the transaction log.
05-11-2009 10:53 AM
Shutdown Daemon Manager, then delete NMSROOT\databases\cmf\cmf.log if it exists. Then run:
NMSROOT\objects\db\win32\dbsrv10 -f NMSROOT\databases\cmf\cmf.db
NMSROOT is the path into which LMS is installed.
After running that command, try running the backup with Daemon Manager down:
NMSROOT\bin\perl NMSROOT\bin\backup.pl ...
If that does not work, then you should just take your license backup, and start again on a supported OS.
05-12-2009 01:16 AM
I've tried, but I get a new error:
cmf.db was created by a differente version of the software. You must rebuild this database in order to use it with SQL Anywhere 10. How can I rebuild the database? Or shall I just reinstall everything?
Thank you again
05-12-2009 09:31 AM
05-14-2009 03:20 AM
I did it.
Thank you.
