LMS 3.1/RME Config management
I want to save configurations of some switches with a "Secured Username" banner telnet access. It seems to work fine sometimes, but often it fails. What could be the problem?
Re: LMS 3.1/RME Config management
What errors do you get trying to archive the config?
I've found a solution modifying the file $PX_DATADIR/objects/cmf/data/TacacsPrompts.ini with the good prompts for username and password.
It seems OK now.
130
