05-15-2009 04:53 AM
Is there a way within CiscoWorks to search through all configurations for a particular IP Helper address, regardless of interface.? Thanks
Solved! Go to Solution.
05-15-2009 06:24 AM
there is the posibility to search in all archived configurations if you go to
RME > Config Mgmg > Archive Mgmt > Search Archive
05-15-2009 06:24 AM
05-15-2009 06:31 AM
Further, you could create a custom query (Resource Manager Essentials > Config Mgmt > Archive Mgmt > Search Archive > Custom Queries) and save it, allowing you to launch or schedule the query to run as needed.
05-15-2009 06:35 AM
Perfect, just what I needed. Thanks!
