LMS 3.1 syslog collector does not start after restart
markschnabel
Level 4
Level 4
every time we restart the server the syslog collector fails to start and we have to manually subscribe. The collector shows up but in a not started status.Any ideas on why?
5 Replies 5
Joe Clarke
This could be a timing issue. Was the hostname on this server changed recently?
no, but we did have a temp server hostname during the upgrade so actually 2 devices show up as options. I have not figured out how to delete the one device that we dont need.
Yes, this is a timing problem. If you wait long enough, the Collector should get subscribed. In any event, you can clean this up by stopping Daemon Manager, then do the following:
* Clear out the contents of NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/filters.dat
* Delete NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/sa/data/collectors.dat
and NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/Subscribers.dat
Then restart Daemon Manager, and the local Collector should be automatically resubscribed.
Thank you for the quick update! I will try this during our next change window. Regarding waiting long enough, after 24 hours it still did not get subscribed.
It worked! Thanks for your assistance.
