LMS 3.1 top ACS 4.1 integration errors
I am attempting to integrate LMS 3.1 to acs 4.1 I am following this solution:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html#wp9000133
However when attempting to put the LMS server into the LMS Server NDG as a AAA client I get an error with overlapping IP address.
I understand this is because I have a NDG called "Network Devices" that contains an AAA client "cisco-devices" with a wildcard IP address of n.*.*.* due to our 4500 cisco devices this ACS handles.
Our LMS 3.1 server is n.117.193.36 so when entering the new aaa client "lmsserver1" with that IP address I get the error regarding the overlap in IP addresses.
I initially thought that the client with the n.*.*.* would cover my LMS server however this client has the Single Connect TACACS+ AAA Client option enabled and the instructions says not to enable this for LMS intergration.
Is there a work around other than splitting the n.*.*.* wildcard up into n.0-116.*.* and n.118-255.#.# therefore freeing up n.117.#.#
Many Thanks
1 REPLY
Re: LMS 3.1 top ACS 4.1 integration errors
There is no workaround. The "*.*.*.*" will work provided you disable single connect. If that is not possible, you'll have to split the NDG range to put the LMS server into its own NDG.
104
