LMS 3.2.1 not discover ML cards(ONS)
raj1000au
I have installed LMS 3.2.1 and RPM(ATM technology) can be seen but not ML card(ONS). Also LMS discovered lot of interfaces (int vlan) one of the core switches and marked them as 'unreachable'. How can delete these when LMS marked as unreachable? Any suggestion is much appreciated.
Marvin Rhoads
The ONS ML100T cards (or any ONS cards for that matter) are not supported devices in Ciscoworks. Please see the supported devices list.
When LMS discovers a devices, it will try to manage all of the device's IP addresses. Unreachable ones (suc as SVIs you can't get to from LMS) need to be manually removed from managed status. It's been a while since I've used an LMS 3.2, but I believe that's set up under detailed device view in DFM.
