LMS 3.2: about menu tells LMS 3.1 rather than 3.2
Customer has upgraded on 02/10 LMS from 3.1 to 3.2 on windows, but when he opens About menu he see LMS 3.1
On Common services -> Software center -> Software update he can see LMS 3.1 but with modules from LMS 3.2 (version.docx).
You will find logs installation.
How it is possible ?
Customer has also CPU and memory that increase more and more, then he must restart LMS process to get a normal cpu and memory.
He must give me later which process are consuming a lot of cpu and memory.
Many thanks for your help,
Elisabeth
1 REPLY
Re: LMS 3.2: about menu tells LMS 3.1 rather than 3.2
This is fine.  This just means you originally licensed LMS 3.1.  You actually have LMS 3.2 installed.
165
