You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
LMS 3.2 Application Registration Fail
Hi I am attempting to register QPM 4.1.5 into LMS 3.2.1 Portal, under Home Page Admin - Application Registration but It fails.
It seems to be a bug where it puts the details in the wrong place when submitting the info.
This is the output that it tries to submit obviously - Description, host name, port number and protocol are mixed up.
You have selected the following application to be imported from the remote server.
Name: QoS Policy Management
Version: 4.1
Description: xx.xx.xx.xx (the FQDN of the QPM server)
Host Name: 443
Port Number: https
Protocol: null
This is the error message that follows.
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.util.NoSuchElementException
java.util.StringTokenizer.nextToken(StringTokenizer.java:332)
com.cisco.nm.cmf.cmic.uii.action.ApplicationStatus.importTemplate(ApplicationStatus.java:444)
com.cisco.nm.cmf.cmic.uii.action.ApplicationStatus.registerApplication(ApplicationStatus.java:411)
com.cisco.nm.cmf.cmic.uii.action.ApplicationStatus.perform(ApplicationStatus.java:120)
org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:509)
javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
com.cisco.nm.cmf.util.AccessLogFilter.doFilter(AccessLogFilter.java:128)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.29 logs.
I'm not sure where to find the Tomcat logs or how much use they would be.
Regards Dean
  • Network Management
Everyone's tags (1)
1 REPLY
QPM 4.1 is compatible with CS 3.2 and LMS 3.2 comes with CS 3.3.
The common Servces compatibilty will not let this registration happen. You can do this only till LMS 3.1, unfortunately.
This is not supported as these software versions are not supported and would not be able to do the necessary communitcation to complete registration.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
329
