Webcast-Catalyst9k
LMS 3.2/ASDM(asdm-615.bin)
I have upgraded LMS 3.1 to 3.2. When I was launching topology services, java used to be upgraded from 1.6.0_05-b13 to jre-6u11-windows-i586-p_withjacorb from cisco works server.
Also i am using asdm-615.bin on ASA5520.
After upgrade of java, i cannot use ASDM, because of error.
I used to downgrade java and I can use ASDM now, but can not use topology services...
Can I change the java version on LMS 3.2, or may be there is a solution for java version capabilities for cisco products?
1 REPLY
Re: LMS 3.2/ASDM(asdm-615.bin)
LMS 3.2 can use JPI 1.6.0_11 or higher only.  You cannot use a JPI version less than 1.6.0_11 with LMS 3.2.
707
