Community Member
LMS 3.2 - Autologout after xxMin of idle time
Hi there,
are there any options to LMS/Portal automatically logout a user having an idle session of xx mins?
Thanks for any feedback
Lothar
Re: LMS 3.2 - Autologout after xxMin of idle time
The Tomcat session will automatically expire are two hours of idle time. This is not configurable.
Community Member
Would it be possible to edit the corresponding tomcat-config file?
Or does editing affect other CW-Processes
[Tomcat_home]/conf/web.xml:
120
Thanks for your feedback
Lothar
This does control the session logout time, but modifying this file is not supported. If you run into problems, you will have to revert before TAC can help you.
183
