LMS 3.2 baseline template not working
I am testing some simple queries using LMS 3.2  baseline templates.
I want to check if CDP is disabled on all FastEtherner interfaces,
Name: fastethernet     SubMode: Yes       isPrerequisite: No
Ordered : No     Prerequisite-Commandset  : none     Parent: none
  interface   FastEthernet[#.*#]
  +   no   cdp   enable
I applied this compliance check on a switch which has interfaces where cdp is enabled. The result still says No Non-Compliant Commands.
Similary, I am testing if "dhcp snooping" is untrusted on all the interfaces.
Name: dhcpsnooptrust     SubMode: Yes       isPrerequisite: No
  interface[#.*#]
  -   ip   dhcp   snooping   trust
When applied to a device which has some interfaces with "dhcp snooping" trusted, the result still says No Non-Compliant Commands.
What I am missing here ?
Sharad
Re: LMS 3.2 baseline template not working
Your submodes are wrong.  Try:
Submode : interface [#FastEthernet.*#]
Submode : interface [INTF]
Hi Joe,
The first submode worked with your modification.
For the second submode, I used space after "interface",
interface [#.*#]
and it worked after that.
Sharad
Yes, I had a space in there.  You used a regexp, but my example would have worked as well.
323
