Community Member
LMS 3.2 CM Discrepancies Fix shows up as wrong username
I recently used the fix option under CM discrepancies to fix three issues. When the job completed and showed up in change audit it had a different username associated with it. The user is a valid user on works. Any ideas why?
Bill
1 REPLY
Re: LMS 3.2 CM Discrepancies Fix shows up as wrong username
There a username for RME one can specify in Campus.
I think it's to be used when the RME is remote, one another server.
Check if the user who did the "fix" job is the user who is configured in Campus as RME username
Cheers,
Michel
142
