LMS 3.2 Device Center options missing after ACS integration
Hi, I just integrated LMS 3.2 with ACS by following the ingegration white paper.
I'm logged on as an admin which is a member of an ACS group has the following ACS settings for all CW applications:
Assign a CiscoWorks for any network device is selected and set to "Super Admin"
Problem: Device enter is missing some options. The only Management Tasks option that appears is "Create Collector". I think I should see more options. Does anyone know what may be the problem?
Thanks!
--Max
1 ACCEPTED SOLUTION
Re: LMS 3.2 Device Center options missing after ACS integration
What version of RME is installed on this server?
This could be an issue with what applications are managing what devices. Post a screenshot of Device Center illustrating the problem.
Hi Jclarke,
Thanks for your reply. Below is a text cut-and-paste (IPs masked) of what I see in Device Center
--Max
Device IP Address 10.x.x.x
Device Type Cisco Catalyst 2950C 24 Switch
Managing Application(s) Device Fault Manager@LMS31, Campus Manager@lms31, RME@lms31, Internetwork Performance Monitor@lms31
CDP Neighbours 10.y.y.y
Functions Available
Tools
Management Station to Device
Ping
Telnet
Trace Route
Edit Device Identity
Edit Device Credentials
Packet Capture
SNMP Set
SNMP Walk
Cluster Management Suite
Cisco View
Mini RMON
Device Troubleshooting
Reports
Device Attributes Report
MAC Report - Dormant MAC
MAC Report - New MAC
MAC Report - Rogue MAC
Port Attributes Report
Switch Port Report - Recently Down
Switch Port Report - Reclaim Unused Down
Switch Port Report - Reclaim Unused Up
Switch Port Report - Switch Port Capacity
Switch Port Report - Switch Port Summary
UT End Host Report
VLAN Report
Management Tasks
Create Collector
Hi Jclarke,
We are using RME 4.3.1.
One thing I noticed in Common Services when I clicked on the ACS button, it said that the System Identity User did not have all privileges. I attached a screen shot. I double checked, and the system identity user is a member of a group that has "super admin" for all CW applications.
--Max
If you have RME 4.3.1, then you are seeing CSCtc21648. A fix is available if you contact the TAC. When you have them, let them do a once-over of your ACS settings to make sure they are okay. However, ACS is not the cause of this issue here.
Thanks JC!
193
