06-10-2010 01:46 AM
I imported 26 devices to DFM. All devices became QUESTIONED, error is SNMP timeout. Here are the troubleshooting steps that I tried:
1. rediscovered devices
2. deleted and rediscovered devices
3. increase snmp timeout settings
4.re-entered snmp strings in device credentials
But I still get the same result.I noticed that devices become questioned so fast.Any advise on this?
06-10-2010 01:17 PM
What version of SNMP you are using on these 26 devices ?Try to do the following:
- Go to Device Center
- Select one device for test
- click on "check device credentials", select SNMP according to the version you are using.
- See the results.
May be you get more technical and detailed information about the SNMP timeout error. I have already experienced some problems using SNMP v3. The problem was resolved when I configured the SNMP v2c instead of v3.
Also, I suggest you to try do "SNMP walk" test in the Device Center. If you get some results reading, for example, the value of "sysObjectId", just verify the Credentials Settings in DCR. You can edit the Credentials trhough the Device Center -> Edit device credentials.
Wando N. Rocha
06-10-2010 08:21 PM
We are using only snmp v2.I have already checked the device credentials but I still get the same result.
06-11-2010 08:02 AM
I suggest you to do a "SNMP walk" test (through Device Center), trying to get the value of the "sysObjectId" and enable the "debug snmp" on the device console. So, through the device terminal, you will see if the device is reacheable by SNMP and why it is not responding to the DFM.
By the way, are these devices supported by DFM? What device model we are talking about? What is the IOS version?
Wando
06-15-2010 10:10 PM
What value should i see? I have checked all the devices and it is supported by DFM 3.2
