11-25-2009 12:02 AM
I have an issues with DFM email notifications in a newly installed LMS 3.2. The problem is that I can see the alerts appearing on Alerts&Activities, but no email arrives. The used SMTP server is working - another applications able to send email notifications via it. My question is which logfiles can give me some information what is the root cause of this problem?
Imre
03-10-2010 10:36 AM
I know those bugs are not affecting you. I filed them. I need to see the new logs.
03-11-2010 01:59 AM
Hi Joe,
Here are the uploaded log files.
Imre
ps: How exactly this notification services works? Can you shortly explain it to me? What process or script do the email sending, etc. Is it possible, that some Windows related thing causes the issue? AV or some missing Windows component?
03-11-2010 02:04 AM
03-11-2010 09:48 AM
I see a bug here, but it's not clear why you are seeing and no one else. If you open a service request with TAC, I can provide you a patch to test. Have your engineer contact me directly to get the patch.
03-11-2010 01:01 PM
Oh, it sounds great I spent a lot of time to try to find out what is the problem. I searched the Bud toolkit, but cannot find LMS 3.2 at all... so I am unable to find the mentioned bug. Can you please send me the bug ID? I will contact with TAC, and ask the engineer to get contact with you for the patch.
Thanks for your help,
Imre
03-11-2010 02:52 PM
The bug ID does not exist yet. This is a new bug, and as I said, I am not sure why everyone is not seeing this. More analysis needs to be done which is why I suggested you open a TAC service request.
03-11-2010 06:55 AM
One more update: VIa the same SMTP server I can get email notification from the other moduls of LMS, e.g. CS sends me email about a successful backup. I checked the other notification types agaai, and I can see, that there is no snmp notification, while SNMP trap forwarding works...
05-28-2010 01:47 AM
Hi there,
Was this challenge resolved? Is it possible to post the source of it and solution?
05-30-2010 10:39 AM
I ended up filing CSCtg43956 for this issue. My patch has been successful for customers so far. The patch is available by contacting TAC.
12-26-2010 02:25 AM
Hi Clarke,
I am having a small quick question.
We are running LMS 3.2
And getting email notifications too. BUt they are so many.
We need to filter it out. Now we get minimum 200 emails from LMS DFM regarding various issues.
Its hard to find out whihc one is critical.
Could you pls help me in filtering this ?
-Shaf
05-21-2010 07:58 AM
Hi everyone.
I'm hitting the exact same issue, but I'm running on LMS 2.6, with DFM 2.0.10. Looked at Bug Toolkit, but I couldn't find any good information there. Could it be possible to be the same bug?
Thanks in advance.
05-21-2010 10:49 AM
No. Start a new thread for your specific issue.
05-31-2010 05:24 AM
Hi Joe,
I just want to inform you, that there is still some poblem with DFM Notificaiton services. The patch was good, but after a while notification sending stopped. LMS was restarted twice since the last email arrived, and there is no email, but there is Alerts in DFM. I have the sam situation earlier wit LMS 3.1, for that issu TAC was unable to find a solution. Any idea what should be checked? I will contact with Nadi Hamarneh as well again to reopen the case.
Thanks for any updates,
Regards:
Imre
05-31-2010 07:09 PM
Yes, definitely reopen the SR. The TAC engineer will collect the nos.log which should provide a starting point for further troubleshooting.
06-01-2010 07:55 AM
Hi Joe,
As I havet the same problem and already installed the patch it did not resolved my problem
The patch I installed is :
ProcessEPMDataManager$EpmDataQueueItem$epmAlarmHistory.class
ProcessEPMDataManager$EpmDataQueueItem$epmConditionHistory.class
ProcessEPMDataManager$EpmDataQueueItem$epmEventProperties.class
ProcessEPMDataManager$EpmDataQueueItem.class
ProcessEPMDataManager.class
nos.jar
After net starting the crmdmgtd still the same issue
The devises are all within KNOWN state but if you look in the notification set up the error message state that the devices are not KNOWN state within the DFM.
Any Clue?
Thanks in advance,
Ron.W
