Community Member
LMS 3.2 Installation - Solaris 10/09 Patch Conflict:
Hello all,
We are running Sun Solaris 10/09,working on installing LMS 3.2.As per documentation,attempted to install the two recommended patches,127127-11 and 122032-05.
The 127127-11 patch is already contained in this OS packaging.The second recommended patch - 122032-05 -  does not install since there exists another patch - 141518-11 -  that makes the second recommended patch(122032-05) obsolete.
The 141518-11 patch cannot be uninstalled since there is no backout data for it.
What do you recommend I do to solve this issue as I cannot move ahead with the installation as things stand.
Should I use an older release of Solaris 10 that is still downloadable from the Sun Website?If so,can anyone recommend a tried and tested release I can use.
Many thanks,
W.
Community Member
Re: LMS 3.2 Installation - Solaris 10/09 Patch Conflict:
Hi all,
Just resifted through the documentation and they have stated the supported releases:
"The following Solaris 10 releases are supported in LMS 3.2:
Solaris 10, 05/09 release
Solaris 10, 10/08 release
Solaris 10, 05/08 release
Solaris 10, 08/07 release
Solaris 10, 11/06 release"
Will give the installation a shot with 10/08.
W.
Community Member
Carried out the installation on 10/08.All is well.
478
