I recently upgraded from LMS 3.0 to 3.2 and applied the latest patches. Everything is fine appart from user tracking acqusittion for IP phones. The phones are discovered in the end host table however each time i start a UT Acqusition it comes back with 0 ip phones in the IP Phone table.
The problem looks like UT isn't working as it should. We are running UCM 7.0.1 and the UCM servers appear normally in CM - we are running CM 5.2.1
Any help in solving this would be appreciated.
Rod
